Shifter Knob issues
Old 05-29-2007, 04:02 PM
98BADAZZTA's Avatar
Default Shifter **** issues
Well, I just bought a WS6 store short stick and when I put my factory HURST **** on the new shaft, It will tighten in a position where it wasnt before. Its not lining up like it should. What do I do? Anybody have problems like this before? If I leave the **** in the position where its supposed to be at, its too loose. How do I go about fixing this problem?
Old 05-29-2007, 04:39 PM
A-Dub's Avatar
I covered the threads in loctite blue, installed the shifter where I wanted it, and let it sit overnight....no issues
Old 05-29-2007, 04:55 PM
styoung's Avatar
loctight is about all you can do, if it doesnt have a jam nut. and good luck getting it back off
Old 05-29-2007, 05:22 PM
mikerulzu's Avatar
You could try a few layers of teflon tape.
Old 05-29-2007, 05:45 PM
sunsetta's Avatar
Back when I bought my **** from MBA, it came with some small thin plastic shims that you put in the bottom of the **** hole to make it tighten up sooner and line up. Figured out which was the correct thickness, installed it and no problem. Make you some thin shims out of maybe some metal flashing or something like that.
Old 05-29-2007, 05:55 PM
joshp14's Avatar
Exactly what sunsetta said, just get some thick paper or flat washers and set them on top of the shaft. Screw the **** down and see if it lines up...if not add or subtract the correct thickness to get it where it needs to be. The blue loctite also works, but sometimes can be a pain when trying to get it back off after the loctite has dried.
Old 05-29-2007, 09:57 PM
Switchblade's Avatar
I used some flat washers - took several tries to get it right.
Old 05-29-2007, 10:06 PM
sdm1234's Avatar
what you can do is use a tap and die to make just a few more threading so it lines up correctly. that's what i did and it works great! (and i can get it off without breaking anything unlike loc-tite). you also won't ever lose shims or washers if you remove the ****.
Old 06-03-2007, 01:58 AM
candlelit's Avatar
I had the same problem with that same stick & ****. I put some tape up in that **** for now, until I get that stick installed in my car to put some gluey glue on.
Old 06-03-2007, 03:01 AM
SS4Luck's Avatar
why not take it to home depot, find a nut that fits over the stick and turn the *** on in the store and see how it goes... that could give youa good starting point
Quick Reply: Shifter Knob issues
