Grinding shifting into second, why?
Old 05-31-2007, 07:08 AM
SSDoubleK's Avatar
Default Grinding shifting into second, why?
I have one of those short throw attach shifters, didn't seem to have the problem with grinding when I first installed it going into second, but it has come loose and I have been tightning it down, also my shift **** (Hurst) I had to tighten this down,pretty good, it also kept coming loose? It seems like second has some play in it, sometimes I can avoid the grinding but not to much, it does it under heavy or light acceleration, Clutch is fully depressed. Thanx for your input.
Old 05-31-2007, 07:30 AM
brad8266's Avatar
Have you done the drill mod? If not you may wanna do that and also drain and replace all hydro fluid and bleed the **** out of it. I had the 2nd gear grind till I did the drill mod on the master cyl braided line.
Old 05-31-2007, 11:58 PM
SSDoubleK's Avatar
I also had this same problem on my 98SS, wasn't as bad as it is on my 2000SS, I will do the free mod. THanx for your input.
