need to know what wire is what from the coil packs...
Old 05-31-2007, 08:56 AM
C Murda's Avatar
Default need to know what wire is what from the coil packs...
im trying to wire in a flame thrower kit and need to know which wire is constant positive and which wire is the fluctuating positive on one set of coil packs? car is an 02 ls1.
Old 05-31-2007, 09:28 AM
C Murda's Avatar
ok well i found the constant positive using a test light but i cant seem to find the fluctuating positive wire....
Old 06-01-2007, 07:37 AM
Ungrounded Moderator
WhiteBird00's Avatar
Each coil has four wires (not counting the spark plug wire). Each has a pink 12V+, a black ground, and a brown or brown with white 12V- reference wire. The fourth wire is the ignitor control wire and is a different color for each cylinder. I assume that's the wire you want although I haven't had any experience with using a car as a flame thrower.
Old 06-02-2007, 07:04 AM
CashMoney's Avatar
This would be fun to do for that ******* that rides your *** down the street.
Quick Reply: need to know what wire is what from the coil packs...
