Shaner VS BBK Throttle bodies
Old 04-30-2003, 07:20 PM
theblur98ss's Avatar
Default Shaner VS BBK Throttle bodies
Just curious which one is a better choice. I have a 422 with a sheet metal intake that can be port matched to 80mm for the BBK. Any suggestions?
Old 04-30-2003, 08:46 PM
DONAIMIAN's Avatar
Default Re: Shaner VS BBK Throttle bodies
If it had stock cubes, id say go with the shanerr. But since your a supperstroker, go with the BBK 80MM
Old 05-01-2003, 02:02 AM
riddler's Avatar
422 with Sheetmetal= BBK, possibly the new TPIS Throttle Body but I don't know enough about that one to recomend. Just my opinion.
Old 05-01-2003, 08:12 AM
SStrokerAce's Avatar
If it's a sheetmetal intake do the 80mm. The advantage to the ported units like mine is the flow/$ and the fact that it will bolt up to the stock intake. Hey it's only $.
Bret
Old 05-02-2003, 01:46 AM
Brandon98TA's Avatar
Contact Shaner. He makes larger models for bigger cubes. His larger ones are actually what LG Motorsports is using on all of their big cube engines. Definetly knows what he is doing. I live in the DFW area so went to his house to pick up mine and he actually had a BBK 80mm there that he was porting for use on a stock motor b/c it didn't flow as well as his. Hope that helps you out some.
Brandon.
Quick Reply: Shaner VS BBK Throttle bodies
