the price of Cheap FI tubing connectors
Anyone run into this?
I installed my STS and was very happy I noticed a slight drop in low end response that I chocked up to the turbo being more restrictive than the muffler, the piping...etc., but I could deal with it. Well slowly the low RPM range has been getting worse and worse, but kinda slowly....ya know. The car would lunge off the line and fall into a hole....start to go and when it boosted, it tore the tires loose.
Guy at work today was under the hood and goes "watch" as he flicked the throttle the 90 elbow going into the TB sucked it self closed. I was like DAMNNN That looks bad. It looks to me like it might be my problem. Anyway who has good connectors that won't rape me?
Remove your air filter and try to do it again. The elbow will suck in if the filter is a large enough restriction. Maybe clean it or put a larger one on there. The silicone hoses have no strength against suction. they are just designed not to blow up under pressure. Or run with just the elbow on and see if that alone will colapse the elbow
mine does this same thing. i think its because when you rev up the car in park, it is only in vacuum and sucks the elbow in, but when your driving it, the boost keeps it "blown up". watch a dyno video of an sts car and you'll see what i mean. when being driven, the elbow expands from the boost!
