How much clearance is required between a spark plug wire and an exhaust manifold?
How many inches of clearance are required when running a spark plug wire in between the primaries on an exhaust manifold? This is for a turbo setup, so the manifold is going to get pretty hot.
-Dave
-Dave
I think any air gap is good enough and heat sleeve hurts rather than helps as it will still transfer heat to the wire. If there is no air gap and the wire is touching, it is cooked no matter what you cover it with. For example, from what I've seen-
1/16th of an inch air gap = no problems whatsoever
Now take that same gap and close it up by putting heat sleeve on the wire = cooked wire
Wow, do you really need that little of a gap?? I was thinking it would fall around a 1/2" minimum. It won't melt or arc off onto the manifolds?
Your results may vary but from my experience any air gap is better than no gap and heat sleeve jammed in there.
Dumb Ass Vette Moderator
Hmm, sounds like people have mixed feelings about the fiberglass boot?
Keith
Thanks for the info! How much clearance do you have between your primaries and the wires, without the boot protectors on?
Originally Posted by cablebandit
ANSWER....5 passes and the wires were very cool to the touch after just a few minutes of cool down. WITH the boots, they would stay hot for a LONG time...so hot you couldnt hold them so my vote is little clearance is needed....and no boot protectors
