Screeching noise.... HELP
Ok, well last night i got my car all set for the dyno (taking it on Tues) I got my exhaust all clamped back up and a bung welded into my exhaust for the wideband to tune. I also installed a check valve in my feed line right at the turbo to prevent the oil from the lines draining into the lower turbo when i shut the car off. Sooo i fired the car up last night and sure enough the turbos were getting oil, GOOD. Tonight i hop in my car to take a drive and i checked and they were still draining (clear line) and i go to leave and as i give it gas like 1k (idles at like 500) and there is a screech i've never heard before, so i immediately put the car in reverse and back into the garage. I swapped out restictor to see if maybe it wasnt getting enough oil and i just resorted to NO restrictor to test it and it still make the noise! Its a simple screech when i give it some gas (quiet at idle). I have no idea what the issue is. I even took the lines off and they are definitely getting oil for sure. I also took off my air filters and checked the compressor wheels, no play in either and they both spin just fine? Any ideas......? please help, any input is appreciate, i want to drive my car into a river!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
how do i do this? I dont want to drive the car anywhere, i'm nervous its something major so i dont want to drive it AT ALL, any ideas what might make a screech noise sort of like nails on a chalkboard?
__________________
I doubt it would be the turbo's they would make the same noise from 500 rpms to 1k.
car DOESNT need to be in gear, i just threw some revs from the TB up to 1k and it made the noise, so its engine. Only thing i've changed since i last drove the car was the check valve.... but they are still getting oil?
So my turbos would make the screech noise right from 500 if they were the issue?
Thanks, really appreciate it!
__________________
if you can recreate the noise at idle, grab a long handled screwdriver and place the tip on various parts and put your ear to the handle of the screwdriver to listen for it. use process of elimination to narrow it down. yeah its a strange thing to do but it works.
They definitely are getting oil, i pulled my drain lines off and fired the car and oil flowed nicely out of them.... My PCV is set up with both valve covers Tee'd to a catch can, other port on pass side valve cover, TB, and Intake blocked off. Breather on catch can and oil fill..... I'm actually scared to start the car....
One thing i was thinking was that i did change the oil drain like that runs from my pump to the timing cover over to stainless braided and it does run pretty close to the belt, but i checked last night with the car off just looking and there is room between them, unless the belt really grows when i hit 1k and it clips it? I guess i just have to run the car and look.
__________________
ok, just went out and its making the noise still this morning, they are definitely getting oil, at least half of the -10an line is full when they are draining and just slight revs gives the screech, i made a vid and am uploading it now so you guys can hear the noise and maybe recognize it as to what it may be? Thanks!
__________________
my pcv is just totally vented, there is nocheck valve in it anymore....
__________________
Okay, here is the vid (works now) http://video.ls1tech.com/video/23617...4000b19304.htm
The first loud *** noise before i start the car is my scavenge pump, then i decide to show the oil draining but need to grab a flashlight, haha. Then you can see it draining in the clear line, then at the end i give it a little gas and you can hear the trecherous noise! AHHHHHH
__________________
PWEEEEFFF, thanks a lot guys, just fired the car with no belt and no noise! Gave it a few revs and nothing and brought it up to prolly like 1,500-2k ish and nothing but a hint of turbo whistle So now i need to figure out what in my belt line is screeching like a ****! Thanks again, i was REALLLLLLLLY nervous!
__________________
hmm, wouldnt it still make that noise if that were the issue with no belt on? I did just swap over to that chromed alternator with a smaller stock pulley so i'm guessing something there isnt lined up right or the alternator is squeeking/belt rubbing somewhere. Thanks for the help! More trouble-shooting tonight after i get back from my golf tourney!
__________________
I think its the pulley on the new alt, im going to lounge around for a while and go troubleshoot later tonight. Thanks for the help everyone, that scared the be-jitters out of me, hahaha.
__________________
