Anyone know how to make the headlights flash with the alarm
Old 05-31-2007, 10:57 PM
5.7Blackz28's Avatar
Default Anyone know how to make the headlights flash with the alarm
Hey i was wondering if n e one knows how to make the headlights flash when the alarm goes off or when you turn the alarm off. I know the turning signals flash and the foglights if u have the switch off.. but i was wondering if n e one knows what wires to put together or what to do so that the head lights flash also.. thanks in advance ...
Old 06-01-2007, 08:40 PM
No one?
Old 06-01-2007, 09:47 PM
defenestrate's Avatar
you have to put your car in program mode which is on section 2 page 21 in the manual. then go to page 24 in the same section and you have 4 modes that you can program. if you dont have a manual or need help, let me know i just went through everything not too long ago. there quite a bit of stuff you can change with the car.
Old 06-02-2007, 05:27 PM
Hey.. yea i dont have the manual is there a way you can help me out with that if its no problem... if you can i'd really appreciate it thanks in advance bro..
Old 06-02-2007, 07:36 PM
no problem man. i got an 02 so i hope its the same for you
putting the car in program mode
1. put the key in the ignition
2. turn the ignition to run to disarm the alarm
3. turn the ignition off
4. remove the radio fuse. this fuse is in the main fuse block, located on the left side of your instrument panel.
5. turn the ignition towards you to accessory.
6. count the number of chimes you hear. you will hear one or two chimes depending on the features your vehicle is equipped with. (you should hear two i think)
arming verification
1. press the lock button on the remote keyless entry.
2. count the number of chimes you hear. the number of chimes tells you which mode your vehicle is set for. ( you want mode 3, so 3 chirps).
3. press the lock buton again until you hear the number of chimes corresponding to the mode selection you want (again, 3)
exiting program mode
when programing is complete, turn the ignition to off and reinstall the radio fuse.
this SHOULD do the trick. if there are any problems i will go out and go through the modes myself. hope it works for ya hit me back if you need help again wih it.
Old 06-03-2007, 06:32 AM
mcamarols1's Avatar
so whats mode 1 and 2 for?? actually what are all the modes??
Old 06-03-2007, 10:35 AM
CashMoney's Avatar
here you go 5.7 http://www.f-bodyhideout.com/techman/2001camaro.pdf
Old 06-03-2007, 06:12 PM
there you go, much easier. hope all goes well. i wish i had the sweet ride on page 1-8
Old 06-03-2007, 08:40 PM
Hey defenestrate i tried it and it didnt work.. do u know what the other settting are for 1 2 and 4.. i have a 4th chime is that supposed to happen? if its no problem can u try it on your car and see if the head lights flash with the alarm??
Old 06-03-2007, 08:51 PM
AZ2ENVY's Avatar
Old 06-04-2007, 09:28 AM
Xx01CamaroZ28xX's Avatar
Any more results???
Old 06-04-2007, 12:34 PM
therobman's Avatar
anyone know how to make t/a headligths flash open and close when alarm goes off
Old 06-04-2007, 01:59 PM
mode one is all off, mode two is horn and parking lamps, and 4 is parking lamps only. are you sure you exited program mode correctly? i messed that up a few times and i think that didnt "save" the mode. yeah man i'll try it, its pouring right now i just got back from work so i'll do it when it stops.
also man, i forgot to tell you earlier but when you first put it in program mode, you will either hear one or two chirps-if you only hear one then that means you are not able to change certain things, the lights being one of them. the chart of what is available to be changed is on page 2-21
Quick Reply: Anyone know how to make the headlights flash with the alarm
