Fast intake and NW 90mm, what else do i need?
What else do i need to purchase for the intake and TB to make them run.
Keep in mind this was a crate LS2 (364/440) and it didn't come with EFI so i don't have any sensors.
I don't have the ecm or harness yet but it's coming from BS3.
These things come to mind:
Fuel rails (recommendations)
Injectors (recommendations)
The heads are AFR mongoose and Comp cam with .600
Headers are ATS Stainless.
Thanks guys,
Rich
Thanks guys,
Rich
Check out the parts thread at the top of this forum, I just posted a GTO accessory parts list. For the intake stuff, don't forget to buy the rubber gaskets for them. You'll also need an adapter from FAST to make the fuel rail fit, I learned that the hard way. I used the stock fuel rail and injectors because I don't have any power adders. I've got a thread on here with my engine set-up and instalation.
I had a long block too and it was a real PITA getting all the parts for assembly. My list covers almost everything but I did miss a lot of bolts and a few sensors, the shop filled in the rest but this will get you started.
I just looked at the list I posted and realized I didn't post many sensors. Off hand, you'll need two O2 sensors, 2 knock sensors MAF and oil pressure sender. The coils can be an issue too, I had a harness built for the round coil packs but it didn't work. There are several versions of coil packs from GM and they all have the same connection. Whatever ECM you use, find the part number of the coil pack that car used and then have the harness made to work with it.
