question for sjm
Old 06-01-2007, 03:54 PM
408Maro's Avatar
Default question for sjm
hey i got a line lock system from you guys in my car and about a month ago i flipped my power switch and the fuse blew out so i replaced it and i was like hmm but i flipped it again today and it blew again. so i my question is do you have any idea why the fuse keeps popping? everything is installed correctly. thanks
Old 06-02-2007, 07:48 AM
nicks2ndz's Avatar
Check along wiring to make sure there is no knicks or cuts that are touching exposed metal....check at connections to make sure they are secure and the same thing isn't happen.....short to ground is common cause for blown fuses
Old 06-02-2007, 02:40 PM
408Maro's Avatar
thanks ill check that out
Quick Reply: question for sjm
