New LS1 Owners - Newbie Tech - just startin on my 99 Z
camaro8498
06-02-2007, 01:20 AM
i got a 99 z28 and i was wonderin what is a good lowering kit to use and how low i can go with out goin to low........
g-ryde1
06-02-2007, 02:38 AM
im about to put an eibach prokit on mine. check out the suspension section and i think there is a sticky with pictures on different suspension setup picks. my personal fav is the eibachs tho.
staringback05
06-02-2007, 03:29 AM
think about your future mods.....exhaust....
then go from there....
carado1984
06-02-2007, 04:25 AM
yeah if you want true duals probably good not to lower.. Youll find that almost everyone that has had both eibach and hotchkis prefers hotchkis because of the ride quality.. It is suppose to lower a little over an inch.. Most will also suggest koni SAs (shocks) which will probably run around 700-800 for the set.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
