What is going on here? Fuel Trims
I was driving home the other night and for no reason my long term fuel trims went to -12.50 and stay there unless i let out or hammer it... they where around -1.56 to 0 . I always have my predetor pluged in so i watch it close. ( Oh at 65 mph)
I had the car dyno tuned with predetor software and the guy told me not to mess with injector slopes at all , but that is the only way i can get the long term trims back up , but i dont want to **** anything up doing that .
With the trims like that the o2 still fluctuate normaly. Anywhere from 40 mv to 880mv ----unless i am in wot and they are stuck at about 935 mv
I guess i would like to know what happen. The car really doesnt seem to run any different exept for the way it idles. Drops between 900 and 500 for quite a will before stablizing!
I am really tired of ******* with this car so tired of this and that every damn time it rains my o2 sensors go nuts .
But hey this is all my luck !
-12ish isn't ideal, but it's better than +12. If you modify your injector tables you will inadvertedly modify your WOT fueling also. If you paid for a dyno tune to tweak your WOT I'd imagine you don't want to screw that up. Just let it be at -12, your other issues are most certainly secondary.
hmmm
OK so lets talk 02 for a minute ........ Mine are reading any where from 40 mv to 830 mv and when in wot they read about 890 to 900 is this normal ? Why do they drop so low is that part of the deal .
The occilation of the O2 sensors when not in WOT is good. The computer is constantly adjusting fueling to be around 14.7AFR. if you have a wideband guage you will see your AFR swing from something like 14.1AFR to 15.1AFR. The fuel trims are adjkusting this. If it finds a cell that its too right then the fuel trims will take fuel away.
So for come reason your car thinks its running 12% richer than needed, could it be faulty wiring, who knows.... perhasp the VE isn't tuned only WOT.
The other thing to take note of when entering WOT although your fuel trims wont adjust in this mode but dosn't it use the last Fuel Trim value as a modifier for your WOT fueling? if this is right you may be running leaner at WOT, however your O2's are saying 935mV you could be any AFR below 14 AFR.
You may just need to tune the VE Table.
Maf = tune maf table
Sd = tune VE table
Originally Posted by txhorns281
Only when the last trim value is a lean condition
Sd = tune VE table
Sd = tune VE table
I'm a fan of this method of tuning as well.... well sorta
I personally like to get the VE near perfect under 2K and really close between 2 and 3K. From there all measured AFR % error goes against the MAF. In no time at all you'll be hitting the commanded number in PE.
