9 Second guys... Wheelie Bars?
How many of you guys use Wheelie bars.... have you ever stood your car up on its bumper? With my rearmount setup.... putting a wheelie bar back there is a bit more challanging... what do you guys think?
Ok... Dave how is that? I picked up both my tires once on an 11 sec flat run... I always lifted one on any of my low 11 runs...
KP... how? Just suspension tunning or what?
Oh yea... I am scared to do it... as I dont want to squat it on the turbo... or bumper... let alone what it will do when I come back down. What do you think effects that most in your suspension? TQ arm? Trailing arms? Panhard? I have heard that airbags in the rear springs helps twist and squat.
Most 9 second cars dont run airbags, a good rear sway bar makes the car leave level. I could tell all about how to hit the tires hard so it hooks and not put the car on the bumper but its a big secret
But in reality everyting on my car is just simple bolt on parts, spent a little time on the scales, I use a long torque arm, make sure your driveline angle is correct, make sure the rear is square in the car, LCAs are are the right angle etc.
I also use timers to control the timing on the first 30-50' or so and adjusting the 2 step up and down makes a big difference as well. Fine line between keeping the front end down and slowing it down. I wouldnt worry about it until the time comes unless you plan on hitting it with everything it has the first time out.
Even running 10's with nitrous, I had all the suspension you can think of - I mean everything. The run I stood it up, it was like the SS had a mind of her own. With the old set-up the only thing that I was missing was the wheelie bars and limiters. Now, the SS has both. I may never need the wheelie bars (with the limiters) but I'm still not going to take that chance.
Oh I agree that suspension tune (in conjunction with appropriate power) is 100% the reason for a great 60'. Also, the 60' can dictate the entire run. Once we get the SS back to the track we are hoping for low/mid 1.2 60'. With the improvements we should be able to finally leave on a good amount of boost.
David
David
