Changes when adding 90/90
Old 06-02-2007, 10:05 AM
algws6's Avatar
Default Changes when adding 90/90
besides the VE and PE tables, what else has to be changed when adding a 90/90?
Old 06-04-2007, 07:37 PM
algws6's Avatar
anyone?
Old 06-04-2007, 07:41 PM
brad8266's Avatar
If you drive a vette they have the electronic throttle settings that need to be changed since theyt are drive by wire and not a cable throttle like the f-bodys. Its the ETC scaler tables in the PCM.
Old 06-04-2007, 08:03 PM
My90Iroc's Avatar
You'll probably have to work your idle. Fast 90/90 seems to make the car real sensitive at idle. You can play with your spark a little also but it's hard to quantify spark changes on the street. If anything back it off a degree or two and try to see if the old butt dyno tells you anything.
Old 06-04-2007, 08:21 PM
Frost's Avatar
I thought most of that over sensitivity was just people trying to tune around the stock scalar?
Old 06-04-2007, 08:59 PM
algws6's Avatar
how much do i have to change it by?
Old 06-05-2007, 06:01 AM
brad8266's Avatar
Im not too sure, I havent actually done that on a vette myself on a vette yet. I believe you pretty much have to let the PCM know the actual airflow area of the TB.
Old 06-05-2007, 07:22 AM
ZL1Killa's Avatar
heard that before , 10-4
i slapped on my combo (but I have a throttle by the cable thing, NOT COMPUTER CONTROLLED) and it worked fine. idled funny at first but cleaned itself up.
HOWEVER, with the computer controlled throttles, you need to look up Phil99Vette....i believe he did a right up on this, and it was something like changing the effective area by 48%....idk exactly what table it was
Old 06-05-2007, 09:20 AM
brad8266's Avatar
48% increase is the change in the ETC scaler table i believe.
Old 06-05-2007, 01:06 PM
ZL1Killa's Avatar
increase or decrease (aka multiplying by 48% to stock table)
