I Need Help!
Old 06-02-2007, 04:43 PM
SSexiness's Avatar
Default I Need Help!
I was in the process of greasing the bearings on my idler pulleys when i ran into a problem. The pulley thT uses a torx bit wouldnt budge and with my luck i stripped it. I was wondering if anyone would know the best method the remove the stripped bolt.
Thanks
Old 06-05-2007, 08:25 AM
Anthony Williams's Avatar
Drill it out and use an easy out(left hand twisted bit) to remove it.
Old 06-05-2007, 08:30 AM
taintedmeat's Avatar
Ouch that sucks. You using the right size torx bit?
