98 trans am TCS not turning on
ok the car came with it. i remember it working when chris owned the car. now that i got everything put back together.(installed a new motor that didnt have 3 holes in it) and i push te button for the tcs to turn on and i get nothing. no light on cluster, no light on the switch. nothing at all. any idea's? somebody said that theres a piece that goes on the throttle body but i dont see it? any info write up's or pics would be greatly apprecated. thanks
- Scottie
- Scottie
well heres the weird thing. engine bay fuse block 2 the one closer to the firewall. it has a tcs fuse port. but only 1 prong in there. there are no cut wires under the fuse block going into the the wire loom. so i can't put a fuse in there. i dunno if i can run a jumper wire or not i put pics up.
