Knock sensor plug different speartech harness??
I'm finally hooking up the harness to the mini, and everything on the speartech harness is perfect except for the knock sensor plug. My knock sensor has one "tang" or lead inside (female) , but the male plug on the speartech harness has 2 leads and is a different shape.
Were there different style knock sensors used on LS1's? This is supposed to be out of an '02 firebird.
"Hey Moe, the knock sensor wire don't fit in the oil pressure sending unit"
John from Speartech emailed- I didn't see the knock sensor plug. Eveything is cool. I was trying to plug it into the oil pressure sending unit
Highly reccomend speartech, especially if you're "electrically challenged" (reterded with wiring) like me.
