Question on installing UMI LCA Relocation Brackets
Old 06-03-2007, 08:45 PM
SS125's Avatar
Default Question on installing UMI LCA Relocation Brackets
Today, I start installing the UMI LCA relocation bracets. I had a bitch of a time lining up the top hole of the relocaton bracket and the original bracket. It was either that was off or the shock hole was off. Finally got it right though. However, what did you guys do with the emergency brake that now doesn't have a bracket to hold it and the brake line that now doesn't have a bracket to hold it. There is a black bracket that had to come off in order to get this LCA relocation bracket on. That bracket had a brake line bolted through it and the emergency brack hooked to it also. What did you guys do to accomodate these things or did you just let them flop around back there.
Old 06-03-2007, 09:37 PM
UMI Performance's Avatar
Post up your e-mail or PM it to me. For some reason we left that out of the installation instructions on the bolt on set, but we have directions on what to do with the brake bracket on the weld-in ones. Send me your e-mail address and I will send over the weld in instructions that explains this.
Basically all you do is cut that brake bracket.
Thanks,
Ryan
Old 06-03-2007, 09:41 PM
SS125's Avatar
thanks, send them to billestes@estesassociates.com
Quick Reply: Question on installing UMI LCA Relocation Brackets
