Parking brake!!!
Old 06-03-2007, 11:13 PM
dansean1's Avatar
Default Parking brake!!!
Ok, guys need your help. My parking/E brake on my 02 LS1 is very loose. When I engage it, it does all the way to the top and barely holds the car. It needs to be tightened up. How does one do this?
Old 06-04-2007, 12:55 AM
Shinigami2x4's Avatar
Jack up the rear and pull the tires off, and the calibers and the E brake should have a separate caliber like that that you can adjust on both sides.
Old 06-04-2007, 02:08 AM
dansean1's Avatar
Should the parking brake be engaged when doing this? How is it actually tightened...a bolt, what mechanism is there that does this?
Thanks
Old 06-04-2007, 02:14 AM
I believe it is a scew and the E brake needs to be unlocked (down) then when its adjusted you can pull the e brake to verify it grabs where you want it to grab
