bcm and ground locations
The BCM is located under the dash on the passenger side kind of behind the glove compartment. I believe there are two grounds and they hook to the lower dash support bracket on the passenger side.
I ment the grounds for the car as well not just the bcm. Like the frame to body ground etc. I don't know where these are or how many to check.
There are several grounds on the car. I believe two on each side lower dash mount, couple on the rear driver side head, few on the pass side block, one or two on driver side of block, and a couple more I can't think of at the momment.
