pop in reverse
pop in reverse
When i put my car in reverse (z28) i sometimes hear a poppin kind of sound...sounds almost like the brakes are grabbing ..can hear it on both sides of the car near the wheel.........its only in reverse and only sometimes...any ideas
Originally Posted by 1WICKDZ
does it jolt the car at all?
popping
i just started noticing mine.....it almost sounds like the posi it popping in and out....mine also seems to do it worse when i turn the wheels....I'm trying to sell my car and want to make sure this is nothing serious before i sell..
Do you guys with the popping have M6 cars? Last summer I was hearing a pop or creaking noise somewhere towards the rear of the car. Whenever I would start to let out the clutch and go backwards, I would hear it. Sometimes worse than others. I was afraid it was the posi or something. I got the car on jackstands and started going over everything with a wrench, and it wound up being loose torque arm bolts, where it mounts to the rear. I used some loc tite and tightened them up, problem solved.
UMI??? what does that stand for...Also, mine doesnt always do it..the other day i was going to let a guy listen to it and it never would do it. so i put it in reverse, turned th wheels and kinda power braked it...then when i started backing up it would do it
