Alpine SPS-17C2 or Infinity REF6022I
ALPINE
Handles up to 250 watts peak power (50 watts RMS)
Aluminum-coated polypropylene woofer with air-injected rubber surround, Nomex spider and square voice coil wire design
1" silk soft-dome tweeter with neodymium magnet and variable swivel
Mounting diameter: 5-5/8"
Frequency response: 35Hz - 30kHz
Sensitivity: 92dB
Impedance: 4 ohm
INFINITY
Handles up to 180 watts peak power (60 watts RMS)
6-1/2" Plus One polypropylene woofer cones with rubber surrounds for increased bass and higher efficiency
1" edge-driven silk dome tweeters for accurate sound reproduction and higher power handling; unipivot design for a customized listening experience
Built-in crossovers
Impedance: 2 ohms
Cutout diameter: 5"
Bottom mount depth: 2-3/8"
These are going in the sail panels and doors of my 97 camaro. should I mix and match: 2 up fron two diff in the rear? I want clarity with good sounding bass much more than volume. I am also thinking of adding a 10" sub stealth box
EDIT cd deck is an alpine 60wX4 have to look ub model # but it has BBE
Sensitivity: 92dB
Impedance: 4 ohm
INFINITY
Built-in crossovers
Impedance: 2 ohms
Cutout diameter: 5"
i bought them (alpines), but did not install them (well,,i did, but them took them back out)WAY to bright for me,,,,,i did install the tweets and crossovers, but left my evolutions in there.
