check out my turbo atap log, race tomorrow.
as you can see everything is sweet till i get to around 4600 when the a/f nosedives.. note that the maf is not maxed out at that point (11250hz)
comments? my p.e. table is flat 1.4 across the board.
<font class="small">Code:</font><hr /><pre>
Engine(RPM)Intake Temp(°F)Long Trim1(%)Long Trim2(%)Mass Air Frequency(Hz)Knock Retard(Deg)O2 Sensor 1 (mV)O2 Sensor 2 (mV)Timing Advance(Deg)
3113 70 -2.3 -5.5 5238.800 0 770 668 36.5
3115 70 -2.3 -5.5 5238.800 0 160 746 36
3124 70 -2.3 -5.5 5346.200 0 455 720 34.5
3129 70 -4.7 -7.8 5925.800 0 725 595 31
3151 70 -1.6 -4.7 6727.100 0 790 812 27.5
3171 70 -1.6 -4.7 6748.500 0 800 803 28
3204 70 -1.6 -5.5 6663.100 0 730 404 28
3221 70 -1.6 -5.5 6814.00 0 90 78 27
3252 70 -1.6 -5.5 7311.00 0 605 95 19
3310 70 0 0 9170.40 0 910 942 19
3383 70 0 0 9696.80 0 930 937 19
3484 70 0 0 10049.30 1 925 924 18
3589 70 0 0 10302.7 0.9 920 942 17.5
3722 70 0 0 10440.4 1.3 930 942 15.5
3802 70 0 0 10583.0 2.6 930 942 15
3940 70 0 0 10621.1 2.9 935 946 15
4046 70 0 0 10655.8 2.6 935 942 15
4170 70 0 0 10736.8 2.5 935 933 15.5
4262 70 0 0 10823.7 2.4 935 942 15.5
4363 70 0 0 10876.0 2.2 935 937 15.5
4414 70 0 0 10966.3 2 935 946 15
4542 70 0 0 11020.5 1.8 880 859 14.5
4652 70 0 0 11071.8 2 825 768 14
4720 70 0 0 11125.5 1.8 790 768 14
4820 70 0 0 11185.5 1.8 745 790 15
4943 70 0 0 11233.9 1.7 805 825 15.5
5004 70 0 0 11185.5 1.5 835 812 16.5
5133 70 0 0 11279.8 1.4 835 829 17.5
5222 70 0 0 11207.5 1.3 855 833 17.5
5304 70 0 0 11215.8 1.2 855 838 17.5
5384 70 0 0 11215.8 1.1 855 842 17.5
5474 70 0 0 11233.9 1 870 846 18
5545 70 0 0 11291.0 0.9 870 851 18
5625 70 0 0 11215.8 0.8 870 846 18
5700 70 0 0 11215.8 0.8 865 838 18
5774 70 0 0 11224.6 0.7 870 842 18
5846 70 0 0 11315.4 0.6 870 842 18
5919 70 0 0 11233.9 0.6 905 634 34
5698 70 -2.3 -3.1 6299.80 0 265 690 33.5
5202 72 -2.3 -5.5 5784.20 0 370 660 33.5</pre><hr />
LS1Tech Co-Founder
Re: check out my turbo atap log, race tomorrow.
Too bad you can't resize that pic it's screwing up the frame...
Looks like you go pretty lean from that point onward.
I plan to run my upcoming blower project at 11.2-11.5:1 AF on the dyno... probably like 950-1000 02's at WOT.
thats code straight from atap.
running richer than 950 makes my car stumble bad.
i know its lean, what i cant figure is why.. like i lost fuel pressure or an injector stuck or something? or (based on the knock) was it actually fine and a-tap just got a bug there?
