Forced Induction - Tried search need Magnaflow Ipipe part# for STS kit
vipvegas
06-06-2007, 12:09 PM
Looking for the Magnaflow I pipe part number. Someone gave us a link in this forumn to the part at summit. tried searching couldnt find.
Blackbird
06-06-2007, 01:21 PM
I got the dynomax version from Summit. May want to search for that.
It and the over the axle pipe were very reasonably priced.
99Z28LS1
06-06-2007, 03:50 PM
i got my special i pipe from trt for $40
they also sold me a kit that deletes the over the axle pipe for $40 too
http://i57.photobucket.com/albums/g209/99Z28LS1/S4020440.jpg
WS6FAST
06-06-2007, 07:16 PM
99z28ls1, do you have long tubes and then exhaust is wrapped all the way back from headers back ?...
CamaroSS_2002
06-06-2007, 08:59 PM
WLK-54064 and WLK-53061 -- found on summitracing
trtturbo
06-06-2007, 09:19 PM
thats the one to use.
99Z28LS1
06-07-2007, 03:32 PM
yes sir
vipvegas
06-11-2007, 02:58 PM
why are there 2 part #'s. Im looking for the exhaust portion that runs over the rear axle feeding the turbo exhaust.
vipvegas
06-12-2007, 02:01 PM
anyone ttt
JAvenger007
06-12-2007, 07:14 PM
Look up those #s on summit. They show a pic of them and you can see which goes over the axle clearly. I think it says in the description too.
vipvegas
06-13-2007, 10:51 AM
description is the same and the pictures look almost identical they are just flipped around
vipvegas
07-19-2009, 08:04 PM
ttt bump anyone
vipvegas
07-19-2009, 08:51 PM
will the Dynomax Performance 53061 that summit sells with 3 inch outside diameter but up to my pipe with sts so I can weld it...
vipvegas
07-28-2009, 11:26 PM
Well ordered pipe, does anyone use this pipe to weld up to turbo exhaust pipe supplied with STS kit? Seems to be the only option for replacement of just that section over the axle and reason for me replacing it is my system is Aftermarket dont know brand no stamping but is full stainless so cant weld...
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
