battery problem (i hope)
So I noticed my volt gauge seems a little lower than normal, all my power works, radio, windows, seats, air all works fine. So went to 2 AZ's in my town an both battery check machines are down. So I parked in the garage an turned the lights on an gave it a few revs an the lights stay the same brightness, the only thing I notice is the little green light on my acdelco battery is very dim, it used to be alot brighter. So does that mean my battery's loosing charge? Im gonna try another AZ tommarow see if thers works, an hope an pray it not the ALT!
Ive never changed the battery in it an its a 02 so im going to assume its never been changed. All I know is the car is running fine just the volts are a little low and the light on my battery is very dull.
Update-- At lunch today I went to O'reillys had him test the Battery and Alt. Turns out the Alt is fine but the battery lost a cell so got a new battery an all is well. Il never go to that AZ again, that guy had no idea what he was doing an if followed his advise id be a few hundered in the hole for a new ALT an a battery! Thanks for the replys
