ss rear spoiler and hood paint question.
Originally Posted by ROUDA
I have bright teal metalic its so tough to match. Its not like any other 1 I seen its close but its different then the paint code.
You should definitely get a blend. If you have a dark-colored car (NBM) you may get away without it, and if you have black then you're pretty much safe. The only concern with black matching is the condition of the used clear coat vs new (affects shininess if you don't know), but that issue is easily rectified with a little bit of detailing know-how.
