Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
what to expect with a 402 and nitrous
Old 06-07-2007, 12:15 PM
choopak's Avatar
Default what to expect with a 402 and nitrous
Please dont flame me, ive searched but i have found to many answers. I currently have a C6 making a little over 500rwhp, on the stock block, AFR 225's, comp cam 283..something. My next step was going to be a built bottem end. I was looking at a few, but the best deal or combination i found is a 402 shortblock http://texas-speed.com/shop/item.asp?itemid=684&catid=3
about 4200.00, im going to use my heads and cam on this block. My compression right now is 11;0.1. What kind of power NA should i be expecting, and what kind of power on the bottle do you think it will make, i was thinking just a 150 shot for now, untill i learn how to drive the car on the hose. Also i am having LG do the work does 7,999.00 sound right for a 402, switching everythng from my old motor too the 402, nitrous install (tnt kit F2) and tune...
thanx in advance
Old 06-07-2007, 12:43 PM
BigRon77's Avatar
You might want to upgrade the short block if you're going to be spraying hard (pistons/rings). Bigger cubes doesn't mean lots of xtra hp, but lots of xtra tq. Nitrous means lots of xtra crazy torque. You can expect no traction and about 520rwhp/480ftlbs motor, 650rwhp/630ftlbs on the bottle, of course these are just ballpark, all combos run differently. You will probably have to pull some timing n/a to spray, so you might not even hit 520 motor only with the new tune.
Your cam is probably a 238/242...not a 283 something. Still decent cam for a 402. Could go bigger if you wanted. Price isn't bad including a short block. I know shops that will do a motor swap for $1500, so with short block right at $6000, $1500 for good, clean nitrous install (including kit with all the goodies), $400 for tune, and you're right there.
LG already has a similar beast they did (with 300 shot dual stage) and 408 iron block putting down over 700rwhp, so they can fix you up.
Old 06-07-2007, 01:19 PM
allngn_c5's Avatar
Sounds close to what Bobby was telling me to do a 402 back when I thought the 346 was shot.
Old 06-07-2007, 06:49 PM
choopak's Avatar
thats a nice car, i live in frisco. Did 21st Do your car?? They did my work, and im very happy with the car, extremely happy.
My next issue i know was going to be traction, i can hook up pretty good on the stock tires making 505/441, but i know when i up the torque its gonna wanna be going sideways. theres no 19' DR, i was thinking about 18's all around with some DR's any recommendations on the offset, tires sizes
was thinking about these
http://www.mickeythompsontires.com/s...ETStreetRadial
ET streets
Old 06-07-2007, 07:15 PM
Z O SICK's Avatar
I have an MTI 402 and NX 150 shot on my car. I think it's got a mild cam and heads. Although I didn't get the dyno numbesr after the timming was pulled, I put down 619rwhp/625 ft lb on one pull and 614rwhp/635 ft lb another pull. I hope this helps.
BigRon77's Avatar
Yep, 21st did mine. I live in Plano/Frisco as well.
I can't believe your hooking on stock tires. I didn't want to run DRs on the street, so I have 11" rims on the back with a 305 (C5 offsets). You can tuck a 325 under the rear on an 11" rim with the right offset (CCW has it down pat).
Mine is a daily driver, so I kept street tires. If you want a good street tire on the 19" rim, Michelin PS2 is the way to go. You can get 295s for stock wheels. Buddy of mine runs a LPE 427 with stock wheels and Mich PS2s and hooks pretty good.
Shoot me a PM if you want some other options for the setup.
Old 06-09-2007, 10:55 AM
GTFORMULA's Avatar
I would expect a blown trans or diff.
Old 06-09-2007, 03:18 PM
will82's Avatar
Location: Somewhere Between Mild Insanity and Complete Psychosis
thanx in advance
Sounds real good, especially considering a lot of people (stupidly) bitch about their prices. I wish I could afford to send him my car. You'll be in good hands.
Old 06-09-2007, 08:22 PM
allngn_c5's Avatar
LG Motorsports is a good place to go for all your performance needs. I would love to go with a turbo'd or supercharged 402. Probably supercharged so that I don't have to get rid of my Pro Longtubes. I have spent a lot of Money at LG Motorsports and I know I will get a good deal on my next project I have them do for me.
Old 06-10-2007, 11:41 AM
Robert56's Avatar
I'm doing a iron 408 fully forged for a 300 shot, basic short block was/is $3900 from LME. Going for an easy 700rwhp and 700/800rwtq, I did get 665rwtq on my stock longblock before a ringland let go. I'll copy my thread from the nitrous section over to here, you may get some insight or ideas, good luck.
Robert
Quick Reply: what to expect with a 402 and nitrous
