Car wont start PLEASE HELP!!!
Ok a buddy and I were installing my nitrous and we were drilling the plastic shroud below the wipers to run the purge and drilled to deep and hit the main harness and broke a few wires so the car wouldnt idle below 2500rpm! We then pulled the harness out a bit to repair the wires, checked all the fuses and relays and now the car cranks and will not start, it seems like I have no spark, (will confirm that later today), I also have a SES light on but no scanner, is it possible that I pulled a wire out of the crank sensor when I pulled the wiring harness a bit or what else could be the problem? The car ran before we pulled the harness a bit to fix the wires.
