I just bought one of those A/C refill kits...Help
Old 06-07-2007, 07:33 PM
growl98's Avatar
Default I just bought one of those A/C refill kits...Help
In the insturctions it say to put the end on the low pressure side.....Where is that? i knbow this is not to detailed sorry. Im leaving soon so i dont have too much more time to work on it. Any help would be great!
Thanks James
Old 06-07-2007, 08:46 PM
Starion's Avatar
The low side is on the aluminum can looking thing right near the battery on the passenger side engine compartment. I needed one of those cans with the adapter that has a 90 degree angle because it was a tight fit.
Old 06-08-2007, 08:14 AM
Weezzer's Avatar
The larger tube is the low side, also the low side should have a bigger nipple than the high side.
If all else fails look on the compressor outlets for "S" or the word "suction"
Thats the low side.
Old 06-08-2007, 10:53 AM
waiting2bl33d's Avatar
it will only fit on one side. so follow your hoses until you see a cap then take the cap off see if it fits. i'm pretty sure its on the accumlator.
Old 06-08-2007, 01:42 PM
blkbird's Avatar
That is correct.... Its on the accumulator (by the battery)
