slp fan switch
Old 06-07-2007, 10:07 PM
LTLRDSS's Avatar
Default slp fan switch
ant body have it, i want to get it to cool down the engine during staging. would this be a good buy or should i get the 160 t-stat
Old 06-08-2007, 06:16 AM
troopercar's Avatar
I'll be installing mine shortly, I'll let you know. You'll need the cooler stat for it to do any good, though. Or you'll be cooling the radiator but not the engine.
Old 06-08-2007, 06:35 AM
omcar's Avatar
get the 160 and the slp switch..i have both..a good mod.
Old 06-08-2007, 07:01 AM
teke184's Avatar
had a 160 stat and an SLP switch in my LT1 for 2 yrs, and i have it in my LS1 for almost 4 yrs now...works great.
low speed seems to keep the temp where it is...high speed draws it right down to the minimum operating temp...which with my setups seems to hover around 170deg in the florida heat.
just don't forget to turn it off....otherwise...dead battery quick!
Old 06-08-2007, 07:31 AM
WILWAXU's Avatar
Had mine for years. Works great for cooling the car down at the track.
Old 06-08-2007, 08:38 AM
02BEAST's Avatar
Would'nt just having it tuned to have the fans come on earlier be easier?
Old 06-08-2007, 10:03 AM
troopercar's Avatar
yeah, do that too for street use but they would run non-stop in Florida trying to keep it really cool.
I like to be able to pop the hood and run the fans in staging with the engine off at the track and let the computer handle it on the street.
Old 06-08-2007, 11:42 AM
omcar's Avatar
I do what troopercar does.
Old 06-08-2007, 09:50 PM
LTLRDSS's Avatar
how much cooler will just the fan switch make the car
Old 06-09-2007, 09:18 AM
teke184's Avatar
as cool as the thermostat will allow it. like i said, with my 160 i typically see an actual operating temp of 170 in florida heat.
as for switch or tune......a tune is several hundred bucks....a fan switch is what $50. that was my reason.
Old 06-09-2007, 09:41 AM
allngn_c5's Avatar
I have zero issues with heat. Even when running hard in 90+* temps or bumper to bumper traffic. Was just at the track, no heat issues there either.
Old 06-09-2007, 09:33 PM
GG01SS's Avatar
I like running fans between passes in the staging lanes too, but be careful when running both fans with car off, it will run battery down. Last year I had to ask a mustang for a jump before I raced him. Junked that stock delco battery, have optima red top now.
Old 06-10-2007, 06:37 AM
allngn_c5's Avatar
I just ran last week (cool temps though) and never had any issues with heat. Oh yeah almost forgot the 2 hr wait in between runs. I'll have to post up and let you know how my car does with some back to back runs under her belt. Hopefully it won't be so busy next time.
