Low oil pressure at WOT
Old 06-07-2007, 11:30 PM
ryansm1's Avatar
Default Low oil pressure at WOT
The engine is a 383 LS1 with a MS3 in a 99 C5.
At idle (600-1000rpm) the car shows between 38 and 41psi. Cruising at 2000rpm, pressure hangs slightly lower (36-40psi).
While accelerating or using any more than half throttle, the pressure drops to around 35psi and will jump up to 43-45psi after letting off the throttle.
I don't think the sending unit is bad (pressure doesn't spike or fluctuate wildly). For what it's worth, the engine makes a consistent tapping, it sounds like it is on the top end of the engine, but I haven't had a chance to further identify it. Oil pressure never runs any higher than 45psi or so no matter how fast the engine turns.
Any ideas or suggestions?
Old 06-07-2007, 11:38 PM
BlackSVT03's Avatar
The tapping COULD possibly be a lifter. Happened to me and a few people I know, sooo thats like my diagnosis for a tapping in the top end now (assuming its not a spring or a pushrod).
As for the PSI thing, sending unit? Check to see if it got damaged if youve swapped intakes lately or anything.
