New LS1 Owners - Newbie Tech - Low coolant light ??? new to ls1's
FromTheFireIRise
06-08-2007, 02:23 AM
hi i just bought a 99 ta an my low coolant light pops up not all the time an sometimes long then short. I checked the fuild its not low could it be the coolant level sensor or other prob???
It's most likely the sensor. You can either replace it or unplug it.
99zee
06-08-2007, 06:47 AM
Probably the sensor. I replaced mine a few years ago after having the problem you mentioned. Be prepared they are proud of the them $$
angel71rs
06-08-2007, 02:21 PM
Disconnect = free. Did it on my SS when it cropped up, will do it on my Z too if needed.
Formula413
06-08-2007, 04:44 PM
Welcome to the F-body, get used to that light. :eyes: I unplugged my sesnsor rather than replacing it, they cost around $50. FYI, the sensor is plugged into the radiator about 4 inches below the cap, next to the battery. If you take the battery out you can just unplug the wire and the light will go out.
FromTheFireIRise
06-08-2007, 10:44 PM
thanks for the help also the coolant looks like more water than coolant im going to have my system flushed by my radiator guy he did a badass job on my stang shit came out that car when i first bought it lookin nasty. would the light pop on due to just water ??? im a mechanic for ford i can rip there motors all day but i have never worked on ls1 an have no real info on them becuase my comps down an im using a friends to ask ?s here thanks for the help i app all the help...
99zee
06-09-2007, 07:19 AM
The sensor just reads the level. Shouldn't make a difference whether its just water or water/coolant. If the lights on and the level if fine, its the sensor.
staringback05
06-11-2007, 04:10 AM
actually the sensor can and does get gunked up, thats one reason why they fail ALOT....unplug the sensor and being motor minded you should be able to stay up on the fluid levels....the fluid should be really bright green
LS1 Freak
06-11-2007, 05:08 AM
GM uses the red antifreeze.I changed mine on my 01SS and I had to use the red stuff.I guess thats what is used on alluminum blocks, thats what I've been told
Mine's orange/red. Dexcool. If it's never been flushed, it won't be green.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
