Master and Slave Questions
I beleive im ordering an exoskel tomorrow. Im gonna do a master and slave cylinder. My question is whats the differance between the 02 and the 01-prior? Does the 02 master require the drill mod? Is the slave from the 02 differant or the same as the 01-prior. Just trying to clear up some confusion. Is there anything else i should order with the clutch other then slave and master cylinder?
wrencher
All the current ones available are the latest updated 02 master. Same for the slave all the last updated design to fit all years.
You cannot get the old ones anymore.
You will need to do the drill mod, the restrictor is still there in place.
