low oil light???
Old 06-08-2007, 10:03 PM
txh0tb0i972's Avatar
Default low oil light???
ok i have a problem.... i was leaving work today and the low oil light came on so i grabbed a few before i left...... so then i put it in and its back to normal.... and oil pressure gauge is moving so am good...... but the low oil light never turned off what can be my problem? i thought it was oil sending unit but it wouldnt move the gauge in the car would it? thx for your help
Old 06-08-2007, 11:15 PM
Quickin's Avatar
Start the car a couple times and turn it off, takes a few cycles to go out.
Mine came on today after driving for 210 miles. I filled it up and the light didn't go out until I started and stopped the engine 3 times.
A FYI, from what I've learned, there's a few different lights that won't just go off right away, it takes a few cycles.
Old 06-08-2007, 11:44 PM
i just went outside and turned it on no light thx for the info
Old 06-09-2007, 12:54 AM
Medic/Z28's Avatar
My low oil light sensor stayed on after my H&C,but install I also don't have A/C after H&C work got done but oh well. They say there's a sensor of course that measures the oil level in the pan and if it gets too low it stays stuck and needs to be replaced. At least thats what I was told. Either way I know my car needs half a quart of oil at @ 1400-2000 miles.
Old 06-09-2007, 01:00 PM
TheLS1Kid's Avatar
Turn the key halfway and hold the odometer button until the low oil light goes out.
That is how you reset it.
Old 06-09-2007, 01:14 PM
Quickin's Avatar
Anything is possible with these cars. For it to get "stuck" implies that it has a moving part, and it doesn't. Its just contacts that sense fluid level.
But my oil light has come on 20 times, all because of actual LOW OIL. And it always resets. Now, my friend removed my starter once and pulled the wire that goes to the sensor in the oil pan and the light would stay on all the time. I just got a new plug, spliced it in to the old wird and it was fixed. Check the wire and the plug, make sure the 4 metal leads in the plug that clips onto the sensor are all making contact and that none have been pulled through.
Old 06-11-2007, 12:47 AM
staringback05's Avatar
are you talking about the low oil light or oil change light?....
Old 06-14-2007, 06:47 PM
Medic/Z28's Avatar
low oil light
Old 06-15-2007, 02:47 AM
check the sensor in the side of the pan
