clutch sticks
Old 06-09-2007, 07:56 AM
02blackws6bolton's Avatar
Default clutch sticks
i have an 02 ws6 ta m6 I just had a new t56 installed at the dealer through my warranty company when i get on it and do full throttle in 1st through 4th the clutch wants to stick to the floor and the shifting is delayed i cant slam any of the gears either when i try to shift hard you can here this noise comming from the tranny and it doesnt want to go in to gear, and then when i go from 60 to 90 in 5th at full throttle the clutch wants to stick. The dealer wants to change the clutch master slave and actuator but the warranty company is telling me that if the actuator master and slave were shot it would do it all the time, so they wont even let the dealer change it because it hasn't failed yet....please help
Old 06-09-2007, 01:38 PM
88zukon36s's Avatar
When i was having the same problem i replaced the master and the slave and still had the problem. When i changed the clutch it fixed the problem.
Old 06-09-2007, 01:48 PM
SVThis's Avatar
i was having the same prob...but i went all out and changed the slave, clutch, and flywheel...dont know exactly what was casuing the prob, but its fixed now lol
Old 06-09-2007, 01:56 PM
SSDoubleK's Avatar
What's the condition of you master cyclinder fluid? Change that out.
Old 06-11-2007, 03:10 PM
Changed The Master Fluid No More Sticking But Cant Shift Hard From 1-2 2-3 3-4
Old 06-11-2007, 03:40 PM
2QUIK4U's Avatar
It is most likely the slave cylinder. My car was doing the same thing and I replaced the master cylinder first and it helped a little but the problem didnt go away until the slave was replaced.
Old 06-11-2007, 04:15 PM
peterock98's Avatar
Try bleeding the system you might have air in there.
Old 06-12-2007, 07:00 AM
LS1TECH Sponsor
badpewter-z's Avatar
drill mod, new slave, new clutch if its a stock clutch . that will fix the issue . those 3 limiting factors will drive you nuts if there not up to par and working correctly . espically if its fine under normal driving but once heat is introduced it gives you trouble.
Quick Reply: clutch sticks
