Please help.
Old 06-09-2007, 11:30 AM
NotthisSS's Avatar
Default Please help.
I just recently did a header install on my 2000 trans am.. i have not had it tuned yet.. i have been experiencing one major problem...the car alot of times will not accelerate when i give it gas and then when i slam it it kicks in and runs fine at WOT. but if i start driving regular again it start to cut out again..any ideas or suggestions? i have replaced the front 02 sensors and spark plugs but not spark plug wires
Old 06-09-2007, 12:05 PM
2formulas's Avatar
are you sure your plug wires are on the plugs
did you take any vac stuff off that might be causing a vac leak
Old 06-09-2007, 12:06 PM
2formulas's Avatar
make sure you didnt crack a plug when you put your headers in. most people take the plugs out for a header swap then replace the plugs with new ones if the olds are stockers.
Old 06-09-2007, 01:02 PM
NotthisSS's Avatar
i put new plugs in after the install... i did have to undo vaccum crap though... i took off the egr but hooked it back up... the only thing is i got race style headers so they arent going into nething..
Old 06-09-2007, 02:07 PM
NotthisSS's Avatar
would more people please give input....ill try nething.
