Gas Gauge?
Your sender will not work with the 04 cluster. You will need to replace the sender in the tank with the correct sender. Call Rock Valley or Ricks Hot Rods and I am sure they know which sender part number you want. Senders only cost about $45, so it is a minor thing.
sawzall wielding director
What are you going to do for a fuel pump? Why not just use the fuel pump/sending unit assembly out of a 99-02 camaro? It should be the correct ohm range and then you won`t have to worry about getting a baffeled tank since it is designed for a tank without baffels. Heres a page on it.
http://www.cardomain.com/ride/716267/3
The truck sending units for the LSx trucks may also be set up with the venturi system so they don`t need baffeled tanks but I don`t know for sure.
