PLEASE HELP! Broke a bolt off in the end of my crank!
I was putting an underdrive pulley on my crank today, and I was using a long bolt to pull it on. The pulley started going on, and I was putting some serious pressure on this thing, trying to get it to seat. Then all of a sudden the long bolt snapped down by the threated area... and I'm fucked. Can anyone tell me how to get this bolt out?
Im not sure if you could drilled and re-tapped while in the block, but being safe and rebalancing the crank and getting it out, I would think pull engine and remove crank? Never heard of this actually happening.
Sorry to hear that happened man
Happens all the time when using a long bolt to pull a pulley on with. That's why a threaded stud should be used instead. You have very few options and none are good. If you were able to use an easy-out and remove the broke piece, the threads are garbage now. You might can get a tap and fix the threads, you have nothing to lose. Your only other option is take the crank out and bring it to a machine shop.
