L92 valve to bore clearance
Originally Posted by Richard@WCCH
The L92's nominal bore size is 4.00". Exactly what measurement are you searching for?
Richard
Richard
The valves aspect to the bore changes as it moves off the seat. The valves move toward the center of the cylinder and away from the bore edge as they leave the seat. Nearest I can tell the closest point of valve/bore distance is as follows:
The stock intake valve (2.160") leaves approx. .153" from the closest valve edge to the bore. The exhaust valve has a distance of .047" from valve edge to bore.
Hope this helps.
Richard
Hope this helps.
Richard
Hope this helps.
Richard
Hope this helps.
Richard
Richard, is this with the 1.590" exhaust? - and both measurements are on what size bore?
Thanks
