motor sits 1inch back after bmr k member sbc swap
put a gen 1 sbc in my 02 trans am. called bmr they sent me the k member for that application. After putting the motor and trans in the trans mount is 1 inch to far back from lining up to crossmember. Then i took measurements of my buddies carbed lt1 and from the back of the firewall 2 the front of the carb his motor sat exactly one inch farther up than mine. Has anybody seen this problem before? Cant figure out if the motor mount arms on bmrs member is wrong
