>>problems after my coolent change
1 Post
HI GUYS I HAV A 99 Z28 and i was changin my coolent today to the green stuff cuz i jus hate dex cool it sucks and turns into chunks of brown stuff, so i flushed out my entire system and then changed my thermostat (stock temp on thermostat) and turned on the heater to flush out the heater core too and after filling up the new coolent i ran the car and added coolent then noticed my fans came on i looked at my temp it it was over 210 degees and then it went to the second white line after to 210 and then i shut it off, can u guys help me figure out wats wrong i need my car tomarow for work, im still confused i dont think i did anything wrong thanks guys
1 Post
well dex coool! i had many problems with that, if seen many gm cars with clogged radiators because of dex cool, and dex cool also causes corosion because of all the chemicals mixed inside, after a year or two dex cool will start to turn into chunks of brown stuff in your cooling system.
1 Post
Originally Posted by ShevrolayZ28
Any problems before the swap? I mean, why change from the Dex?
But ya, remove/replace the t-stat and try it. Or maybe something else has clogged it up.
well i had no problems b 4 just got the car so i just wanted to change it because it was pretty old but i was thinking bout stuck thermostat and i also took off the upper hose that connects to the water pump and i noticed there is like no coolent in the block so im gonna fill up the block pretty sonn im gonna go buy some more coolent first tho but ill let u know how it goes thanks
Originally Posted by ae13291
should i bleed the air by keeping the rad cap half way tight
