ARP head bolts...anyone else have problems with stripping?..
Old 06-10-2007, 07:58 PM
Stroker2112's Avatar
Default ARP head bolts...anyone else have problems with stripping?..
Guys,
Whats the best way to get stripped ARP bolts off a cylinder head?...This pisses me off...I was especially careful when torquing them down...now only about 1/2 are coming back out..the rest are slipping off the socket big time. My plan was to swap out the bolts with studs while doing some other work ..now I have to rethink the situation.
If this was your situation would you drill out the bolts?..How easy/hard is this on an ARP bolt? My bolt removers don't seem to want to grab the ARP head either...
Old 06-10-2007, 08:36 PM
Tainted's Avatar
that really sucks. maybe you can weld a socket to the head of the bolt or something
Old 06-10-2007, 08:48 PM
02SOMWS6's Avatar
you shouldn't be slipping with a 12 point socket
Old 06-28-2007, 01:16 AM
Dmoney's Avatar
Did you figure a way to get them off ???? I have a couple of the top ones stripped and was wondering how you got them off......
Old 06-28-2007, 04:01 AM
Xtnct00WS6's Avatar
Are you using 12 point socket? Cause that'd be bad. If the bolt is rounded off a bit, maybe u could try the gator grip universal socket?
Old 06-28-2007, 05:09 AM
vettenuts's Avatar
Are you using the correct size 12 point? A 12 point gives you more contact than a hex head bolt, this shouldn't be happening unless something is wrong.
Old 06-28-2007, 09:23 AM
11Second Club
Gauge's Avatar
I'd be surprised if the bolt is rounded. I've got ARP head bolts, and I've had a couple sockets slip off of them... however, the bolt split the socket both times... the head of the bolt never took any noticable damage.
Quick Reply: ARP head bolts...anyone else have problems with stripping?..
