Cam retaing plate
Old 06-10-2007, 10:25 PM
CNTLSE 1's Avatar
Default Cam retaing plate
Put new cam in putting the retaining plate back on torqueing the bolts to 18lbft and the top one never tightened. pulled it out and with the bolt came the threads. put an end to my so far successful night. should I heli coil or drill and tap? Never done a heli coil and don't know much about it. any help is appreciated.
Old 06-10-2007, 10:30 PM
BriancWS6's Avatar
With the heli coil you will be drilling it out larger, tapping it, and then installing a stainless steel insert that will have threads inside of it, so you can utilize the original size bolt. I would go this route if I were in your shoes.
Old 06-10-2007, 11:54 PM
CNTLSE 1's Avatar
sounds like I should but not sure if there is enough material there
Old 06-10-2007, 11:59 PM
Tainted's Avatar
what if he got a bolt and jsut loc tited the **** out of it if hes got enough threads to hold it? the bottom one of mine stripped a bit but i still put it in, it was only like the bottom 2 threads, im thinking about just putting some loc-tite on that 1 bolt to make sure it doesnt move but I dont think it will anyhow
Old 06-11-2007, 12:09 AM
CNTLSE 1's Avatar
I would leave it out before I did that. if it falls out that is going to spell diaster
Old 06-11-2007, 06:32 AM
CNTLSE 1's Avatar
any more help?
Old 06-11-2007, 08:54 PM
BriancWS6's Avatar
You will completely drill the old threads out, and the new hole will be larger by a fair amount when compared to the original one. Then, you'll tap it, screw the heli coil in, and you'll now have the correct sized threaded hole inside the heli coil.
A heli coil is basically a tubular piece of steel thats threaded externally as well as internally. The external threads will match that of the tap that comes in the kit, and the internal ones you must match to your original bolt, or a new bolt that you wish to use.
Old 06-11-2007, 11:06 PM
CNTLSE 1's Avatar
heli coil fixed her right up
Old 06-12-2007, 08:44 AM
GuitsBoy's Avatar
Good news. I would have highly suggested it... Loctite or epoxy the crap out of it if youre worried about it. I dont see it being any more likelyto fall out than if a bolt fell out. Neither would be a good thing. I think youll be fine though.
Old 06-12-2007, 05:02 PM
BriancWS6's Avatar
Great news
Old 06-13-2007, 10:07 AM
PortPros1's Avatar
You have to heli coil this bolt! do not try loctite! These motors have an issue with the cam retaining plate threads stripping out. If you don't fix this correctly you will regret it later.
Old 06-13-2007, 02:03 PM
Xtnct00WS6's Avatar
I'm glad to see the helicoil worked for you too. I did the same thing to a lifter tray bolt and it worked great!
Old 06-13-2007, 04:11 PM
BriancWS6's Avatar
He already posted that he fixed it with a heli-coil....
