Truck Manifold 1st Gen
I have a 68 firebird I was interested in doing a 5.3 or 6.0 in (cheaper to do a swap than an ls1). Was hoping someone could say definitively whether a factory vortec manifold and accessories will fit under a stock firebird (non-400) hood. Seems like something which has been tried many times and someone on this board could say. Searching the posts here I Get the idea that there is some extranous casting material on the top of the manifold which, if removed, could allow a factory hood to close. Thanks.
From what Ive seen the manifold wont clear the hood unless its a hi-rise. It would be eaiser to swap to an ls1 intake and sell the other. They are only $50 or so. The accessories should work expect for the a/c.
The truck accessories will also put the alternator very close to the hood.
Your best bet is to set the engine it place with a floor jack under the pan
and see what clears. You can usually move the engine around a little to get in
a spot with the best possible clearance.
Make note of the trans position before you move the engine forward or back so that
you know how much to alter the length of the driveshaft if needed.
Thanks for your answers!
I don't mind changing the intake manifold, but I read some guys post saying if you change the manifold, you have to change the accessories (water pump, at least), fuel rail, and maybe the injectors, etc. True?
I'm trying to put together the most cost effective LS swap I can (just cause that's part of the fun, I'm cheap, and I have a 'vert so I'm satisfied with stock power), but if the money you save in an iron block truck motor is ate up in oil pans, accessories, intake, etc., then it's not worth it.
Custm2500's #1 Fan
