? about final assembly
Old 06-11-2007, 08:48 AM
Superjoe's Avatar
Default ? about final assembly
Hello, I've torn my engine down to put new heads on and I'm wondering if there is any way to lube the motor before I crank it over again. It'll probably have been sitting for about 3 weeks total before I have it back together. Would it kill it to put a light coat of oil on the piston/ring/cylinder wall before I put the heads on? Just don't want to start the whole thing up dry if I can avoid it. Thanks!
Old 06-11-2007, 04:12 PM
zmonsterjb's Avatar
just crank it up and whatch the oil pressure!
zmonsterjb's Avatar
and you could also disconnect the coils and turn it over a couple of time until you think it is primed a little.
Old 06-11-2007, 04:40 PM
GuitsBoy's Avatar
pull the coil fuses... and the fuel pump fuse too..
