Which T56?
Old 06-11-2007, 11:32 AM
nobreaks254's Avatar
Default Which T56?
I posted this over in the Manual tranmission section, but maybe I'll get more response here.
Yes this is my first post here but I hope you all can help.
I'm doing a 6.0/T56 swap in my 79 Z28. Ive got the motor but I need to find a tranny.
My question is there any years that are better than others or all they all the same? Does it have to come out of a 98-02 F body or will a Viper or Mustang unit work with a different bell? How about GTO or Caddy CTS?
Thanks in advance for your help!
Old 06-11-2007, 12:43 PM
enganeer's Avatar
For a T56 they are not all the same.
Strongest to weakest:
Viper
GTO, CTS-V
F-body
Mustang
Mustang and Viper would require a different bell housing.
Old 06-11-2007, 12:57 PM
I would imagine the output and input shafts are different on the Mustang and Viper transmissions? So they should all bolt up to a LS1 bellhousing or would they need an adaptor? What about shifter locations?
Anyone?
Old 06-11-2007, 01:34 PM
bczee's Avatar
I am using a Viper T56 with my 99 LS1 in my Chevelle... the Input shaft has to be swapped over to the F-Body and the front adapter plate also needs to be swapped out.
If you don't swap out the Adapter plate, you can not bolt up the Slave. but the Bellhousing will still bolt up ok. You can modify the Slave by re-drilling the slave with the correct clocking of the bolt holes. But it would be better to swap the plate.
Shifter location are all different.. the Viper is forward of the F-Body and the GTO having a more rear mounted setup. The Viper and Mustang (02-04 Corbra) can share the shifters.
Old 07-03-2007, 03:25 PM
BoOsTeDeAgLe's Avatar
Anyone know if the f-body style will bolt up to a 358, or will I need a different bellhousing? It's going into a 96 s-10.
Old 07-03-2007, 03:43 PM
the ls1 bell will bolt up with the exception of one bolt hole. But I think you would want to use a 93-97 f-body T56 on your SBC.
Old 07-03-2007, 03:50 PM
OK, thanks
Old 07-03-2007, 04:05 PM
bczee's Avatar
if your going to swap in a T56 to your SBC.. suggest you look into a LT1 T56 (93-97) due to the different in the flange to crank and input shaft differents with the LT1 vs LS1 T56's...
Old 07-03-2007, 04:48 PM
a10beav's Avatar
Take a look at D&D Performance, they build T-56's for almost any application. They have GM types with a Viper back half, the shifter is offset to the drivers side but the shifter is in the stock location on my '88.
Old 07-03-2007, 05:41 PM
I don't really know much about t56's, but would you say it's strong enough in stock form + clutch for ~580whp on motor, plus 200-300 on nitrous?
Also, I know this is a stupid question to some of you guys, but is the 93-97 still a 6-speed?
Quick Reply: Which T56?
