HELP.driver side window just sopped going up or down
Old 06-11-2007, 07:08 PM
HIZPANICGUY21's Avatar
Default HELP.driver side window just sopped going up or down
the window motor is 6 or so months old..this is the weird part about it.all the others controls on the driver's side switches work....i can control the passengers window normally..i can lock/unlock both doors from drivers side control switches..i can reposition both driver and passenger side mirriors..the only thing i cant do is control my drivers side window..it just took a **** on me..would anyone know what the hell might be wrong with this crap
Old 06-11-2007, 07:21 PM
SupermanSS's Avatar
I'm guessing the switch itself is worn out, my 98 got to be like that and I had to replace the switch.
Old 06-11-2007, 07:39 PM
KEE AUDIO's Avatar
Hopefully it is just the switch. You say your window motor is 6mo. old? Did you buy the el cheapo one off ebay or spring for the upgraded one. I've heard people sometimes have issues with the cheap $20.00 one. I replaced mine with the $50.00 one and have had no issues in the last year since I put it in.
Old 06-11-2007, 08:06 PM
Ungrounded Moderator
WhiteBird00's Avatar
It is far more likely that the window motor is gone again than that the switch is bad. But it's easy to test...use a test light or multimeter to check for power output on the light blue and tan wires at the switch when you use it. The output should change polarity when the switch goes from the up position to the down position.
ITS A $50 ONE...i went to walmart and roled my windows down..when i was getting out to go into walmart..i tried to put the windows up, and the driver side one didnt do ****..so i hope its the switch..any idea how much for the switch? the whole thing right? the switch plate with all the switches(both window switches...unlocking doors, and side mirriors)
Old 06-11-2007, 08:15 PM
That_guy's Avatar
that just happend to me friday lol but i think its the switch my motor is fine except it goes to slow. But check the switches
Old 06-11-2007, 08:21 PM
The Professor's Avatar
damn this just happened to me too. mine goes down fine but then gives up after going back up a few inches. if i leave it alone for about 10 min, it will go up another inch or so and then it needs a break again before it will go up anymore; so it takes me like 30 min to put the window all the way up. is that the motor?
Old 06-11-2007, 08:31 PM
presto_z's Avatar
yes its the motor.. go to discount auto spend 50 bucks on one and it comes with a lifetime warranty.. dont waste 20 bucks on a ebay one
Old 06-11-2007, 09:59 PM
Since i could still control the passenger side window does that mean that....... (SEE ILLUSTRATION BELOW)
Old 06-11-2007, 10:17 PM
bigfoot2thefloor's Avatar
will one from the other working window fit on the driver side...that would help narrow down what piece you need.. mine stops working to sometimes mainly conviently when im about to pull out of the staging lanes, up to the christmas tree and need to roll my window up..but I wait a cupple seconds and it usually works again..
Old 06-12-2007, 12:05 AM
no it wont..the driver side switch has 6 metal prongs where as the passenger side switch had 5..but thanks...anyone else?
Old 06-12-2007, 06:49 AM
Interesting how many people are ready to replace parts based on assumptions rather than taking a few minutes to test. You could be right...it may be the switch...but why not test it to be sure instead of guessing?
If you need to replace the switch it is the part in the second picture - the first part is just the harness connector.
EDIT: If you have a 97-02 Camaro, the switch part number is 10402842 - about $16 retail.
Old 06-12-2007, 01:08 PM
thingthatgoes's Avatar
Originally Posted by WhiteBird00
Interesting how many people are ready to replace parts based on assumptions rather than taking a few minutes to test....
My $ is that it's the thermal coupling (which is in the motor itself).
My suggestion is that if it is the case consider bypassing it or get a new motor. No matter what you do, use the Autotrix kit on both windows to prevent this from happening again.
Old 06-13-2007, 10:09 PM
GOT IT FIXED.... i was right. it was the switches!!!! got it from the dealer for $19
Old 06-13-2007, 10:21 PM
presto_z's Avatar
i dont think they have the autotrix for the drivers side.. or do they?
Old 06-13-2007, 10:27 PM
You Know Im Not To Sure..i Know For Sure They Have The Passenger Side...hm..i Donno
Old 06-14-2007, 02:14 PM
KEE AUDIO's Avatar
Cool!! I'm glad it was the switches!!
Old 06-19-2007, 04:31 AM
6LITEREATER's Avatar
Are you sure it was just the switches? I'd bet $10 if you leave the car parked outside in the sun again you'll find the motor is the culprit...
Old 06-20-2007, 01:35 PM
$10 Huh......hm...(if Youre Serious) ....i Win!!! Car Has Been Parked In 100+ Weather Already..( I Live In The Antelope Valley...really Really Hot During Summer) And Its Been Functioning Perfect..wheres My $10..i Take Paypal :-)
Old 07-01-2007, 08:39 PM
Closed ex-Sponsor Account
autotrix's Avatar
Nope no drivers side cure just yet. Sorry
