General Maintenance & Repairs - Fix your leaking t-tops.
View Full Version : Fix your leaking t-tops.
2001somws.6
06-11-2007, 07:59 PM
Just a few months ago i took my car to the dealership to have my window remounted because it wasnt sitting tight with the molding causing it to leak really bad. So now after a few months and now i have been getting hit with some heavy rain and not to mention i aim the hose right at the spot were it would leak. And nothing. :judge: :)
There is a rivet that holds the window arm inside the door that keeps it up and tight along the molding. This rivet was making the original hole larger and making the rivet to sag and the window too thus letting water to leak in. :cry:
They remounted the rivet and tighted the window arm to sit tight along the molding with the t-top. This made me sure that its not the molding but from not having a tight firm seal with the window and the molding. :) :)
Any questions? :chug:
partyhardoo69
06-11-2007, 08:30 PM
how much did you pay?
2001somws.6
06-12-2007, 03:55 PM
Only $80 bucks.
SCRWS6
06-12-2007, 07:00 PM
hmmm.... di-electric grease worked for mine though.....I heard it expands the rubber though, so same idea, different way of doing it. just keeping the seal tight.
staringback05
06-13-2007, 03:16 AM
the grease works fine, mcguires also makes a product strictly for weather stripping
