best gear for C5 on the bottle
What is the best gear for my C5 6 speed stroker on a 250 shot?
I have been told that the stock 3.42 gear would work best on the bottle.
This will be used on 1000ft and 1/4 mile drag.
any help would be appreciated
I bought a NEW Z06 3.42 rear diff and replaced the long shaft with a 300mm shaft. GM has a 12/12 warranty on there diffs.
Thanks for all the input and help on this issue guys.
Problem is solved for now.
Wouldn't a Z06 Transmission be advantageous due to the very high low gear ratio . It would seem so with the closer ratios keeping the engine right in the middle of its power band. I know the RPM's drop very little between gear changes & I've heard that the Z06 transmissions are very heavy duty and robust & have been compared to the now famous M22 rock crusher .
