valve noise at full throttle
Old 06-11-2007, 10:28 PM
sd2001ta's Avatar
Default valve noise at full throttle
i have an 01 t/a and at wide open throttle valves make a pinging noise with 93 oct fuel. any suggestions on how to fix this problem?
Old 06-12-2007, 08:31 AM
GuitsBoy's Avatar
Change your fuel filter if you need to. Run some techron fuel injector cleaner. Run some seafoam through the intake to clean out the carbon. consider a catch can if youre getting oil in the intake.
